Advanced files rename on SFTP/FTP server
Simple rename with operation mask
With WinSCP scripting, you can use an operation mask to do simple batch changes to file names like:
  • changing an extension: mv *.htm *.html
  • adding a suffix: mv *.html *-backup.html
  • changing leading characters: mv new*.* old*.*
Advanced rename with PowerShell
But for more advanced rename operations, you need to use your favorite scripting language language, like PowerShell, to generate a new name and use WinSCP .NET assembly for the actual rename (or generate a script file).
The following example renames files using a regular expression.
# @name         Batch &Rename...
#                   -sessionUrl "!E" -remotePath "!/" -pattern "%Pattern%" ^
#                   -replacement "%Replacement%" -refresh -pause -sessionLogPath "%SessionLogPath%" ^
#                   %PreviewMode% !&
# @description  Renames remote files using a regular expression
# @flag         RemoteFiles
# @version      7
# @homepage     https://beta.beta.winscp.net/eng/docs/library_example_advanced_rename
# @require      WinSCP 5.19
# @option       - -run group "Rename"
# @option         Pattern -run textbox "Replace file name part matching this pattern:"
# @option         Replacement -run textbox "with:"
# @option       - -run -config group "Options"
# @option         PreviewMode -run -config checkbox "&Preview changes" "-previewMode" ^
#                     "-previewMode"
# @optionspage  https://beta.beta.winscp.net/eng/docs/library_example_advanced_rename#options
param (
    $sessionUrl = "sftp://user:mypassword;[email protected]/",
    $remotePath,
    $pattern,
    $replacement,
    [Switch]
    $pause,
    [Switch]
    $refresh,
    $sessionLogPath = $Null,
    [Switch]
    $previewMode,
    $files
try
    if ($previewMode)
        $anyChange = $False
        foreach ($file in $files)
            $newName = $file -replace $pattern, $replacement
            if ($newName -eq $file)
                Write-Host "$file not changed"
            else
                Write-Host "$file => $newName"
                $anyChange = $True
        Write-Host
        if (!$anyChange)
            Write-Host "No change to be made"
            $continue = $False
        else
            Write-Host -NoNewline "Continue? y/N "
            $key = [System.Console]::ReadKey()
            Write-Host
            Write-Host
            $continue = ($key.KeyChar -eq "y")
            if (!$continue)
                $pause = $False
    else
        $continue = $True
    if (!$continue)
        $result = 1
    else
        # Load WinSCP .NET assembly
        # Setup session options
        try
            Write-Host "Connecting..."
            Write-Host "Renaming..."
                else
                    $fileMask = [WinSCP.RemotePath]::EscapeFileMask($file)
                    $sourcePath = [WinSCP.RemotePath]::Combine($remotePath, $fileMask)
                    $operationMask = [WinSCP.RemotePath]::EscapeOperationMask($newName)
                    $targetPath = [WinSCP.RemotePath]::Combine($remotePath, $operationMask)
                    $session.MoveFile($sourcePath, $targetPath)
        finally
            # Disconnect, clean up
            $session.Dispose()
        if ($refresh)
            & "$env:WINSCP_PATH\WinSCP.exe" "$sessionUrl" /refresh "$remotePath"
    $result = 0
catch
    $result = 1
if ($pause)
exit $result
Options
In the “Replace file name part matching this pattern” box, enter a regular expression pattern to look for in file name(s).
In the with box, enter a replacement string to replace the file name part that matches the regular expression with. The replacement string can use $x syntax to refer to the x-th group (subexpression in parentheses) captured by the pattern.
On the image, you can see a pattern ((\d{4})-(\d{2})-(\d{2})) and a replacement string ($2-$3-$1) that change date stamp in file names from the yyyy-mm-dd format to the mm-dd-yyyy format by changing an order of captured groups.
Check the Preview changes checkbox to see and confirm the changes in file names before actually renaming the files.
