Two-way synchronization with delete with SFTP/FTP server
WinSCP synchronization functionality is state-less. So when there is a file on one side, which is absent on the opposite side, WinSCP is not able to determine, if the file was added on the first side, or removed on the latter. For this reason in the Both direction, WinSCP does not support the Delete files option.
This extension uses a cache file to remember the list of local files after the previous synchronization. It uses the cached list to determine, if the file was added or removed.
You can install this script as a WinSCP extension by using this page URL in the Add Extension command.
powershell.exe -File C:\path\SynchronizeTwoWayDelete.ps1 -sessionUrl "sftp://user:password;[email protected]/" -localPath "C:\local" -remotePath "/remote" -listPath "C:\cache\example.txt"
# @name         Two-Way Synchronization with Delete...
#                   -sessionUrl "!E" -localPath "%LocalPath%" -remotePath "%RemotePath%" ^
#                   -listPath "%ListPath%" -refresh -pause -sessionLogPath "%SessionLogPath%"
# @description  Synchronizes files on local and remote directories including file deletions ^
#                   by remembering a list of previous local files
# @version      2
# @homepage     https://beta.beta.winscp.net/eng/docs/library_example_two_way_synchronize_delete
# @require      WinSCP 5.18.1
# @option       - -run group "Directories"
# @option         LocalPath -run textbox "&Local directory:" "!\"
# @option         RemotePath -run textbox "&Remote directory:" "!/"
# @option       - -run group "Options"
# @option         ListPath -run textbox "Re&member previous local files in:" ^
#                     "%LOCALAPPDATA%\WinSCP\TwoWayDelete\!N.txt"
# @optionspage  https://beta.beta.winscp.net/eng/docs/library_example_two_way_synchronize_delete#options
param (
    $sessionUrl = "sftp://user:mypassword;[email protected]/",
    $localPath,
    $remotePath,
    $listPath,
    $sessionLogPath = $Null,
    [Switch]
    $pause,
    [Switch]
    $refresh
try
    # Load WinSCP .NET assembly
    # Setup session options from URL
    $listPath = [Environment]::ExpandEnvironmentVariables($listPath)
    $listDir = (Split-Path -Parent $listPath)
    New-Item -ItemType directory -Path $listDir -Force | Out-Null
    if (Test-Path $listPath)
        Write-Host "Loading list of previous local files..."
        [string[]]$previousFiles = Get-Content $listPath
    else
        Write-Host "No list of previous local files"
        $previousFiles = @()
    $needRefresh = $False
    try
        Write-Host "Connecting..."
        Write-Host "Comparing files..."
        $differences =
            $session.CompareDirectories(
                [WinSCP.SynchronizationMode]::Both, $localPath, $remotePath, $False)
        if ($differences.Count -eq 0)
            Write-Host "No changes found."
        else
            Write-Host "Synchronizing $($differences.Count) change(s)..."
            foreach ($difference in $differences)
                $action = $difference.Action
                if ($action -eq [WinSCP.SynchronizationAction]::UploadNew)
                    if ($previousFiles -contains $difference.Local.FileName)
                        $difference.Reverse()
                    else
                        $needRefresh = $True
                elseif ($action -eq [WinSCP.SynchronizationAction]::DownloadNew)
                    $localFilePath =
                        [WinSCP.RemotePath]::TranslateRemotePathToLocal(
                            $difference.Remote.FileName, $remotePath, $localPath)
                    if ($previousFiles -contains $localFilePath)
                    else
                        # noop
                elseif ($action -eq [WinSCP.SynchronizationAction]::DownloadUpdate)
                    # noop
                elseif ($action -eq [WinSCP.SynchronizationAction]::UploadUpdate)
                else
                    throw "Unexpected difference $action"
                Write-Host
