Using Winscp script to submit JCL to JES on IBM Mainframe
I have tried to convert the ftp key word quote to use call in this script:
@echo off
/log="D:\DATA\log\SendJCL.log" /ini=nul ^
/command ^
"open ftpes://UID:[email protected]/" ^
"Call site filetype=jes" ^
"put -transfer=Ascii d:\data\jcl\MyJOB.JCL" ^
"exit"
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
It stops after the open statement with a WinSCP command prompt
I then paste the call command at the prompt: winscp>Call site filetype=jes ^
then paste the Put command at the prompt: winscp>put -transfer=Ascii d:\data\jcl\JOB.JCL" ^
and the job is submitted successfully.
I Cannot figure out why it is not processing the entire script automatically
any help is appreciated
@echo off
/command ^
"exit"
echo Success
) else (
echo Error
