Powershell script to ftp folder
cerealkiller
I just installed winscp, and tried the following ftp script.
Add-Type -Path "C:\program files\ (x86)\winscp\WinSCPnet.dll"
$sessionOptions.ParseUrl("ftp://johntales:[email protected]/")
$session.PutFiles("E:\website\*", "/site/root").Check()
$session.Dispose()
Which copies the folder and subfolders over. But is there a way to display the files that are copied in the powershell command, so I can see at what file he is copying. (so I can see the progress in the powershell window?)
Does this script list failures, if it somehow cant copy a filer/folder? Or list success or fail at the end?
thanks!
