Only download files from root, not from subfolders
[email protected]
Germany
Hi
I've got a script in VB that works fine. But I only would like to download files from the root folder, not out of subfolders. Is it possible to configure this, e.g. with the parameter "remote path" or with "file mask"?
parameter for "root path" -> './.' , 'c:\TMP\DC\XML' , '*.XML' , 'c:\TMP\protokoll.txt')
Can I add some information to exclude subfolders?
Thank you very much for a little help :-)
regards
Stefan
