Trying to connect to a second machine via Advanced->SCP->Shell
mahmood
Recently, I have reinstalled Ubuntu on a remote machine. To connect to the machine from home, I have to ssh to a gateway and from there I have to ssh to the local machine I want. Therefore, in the gateway, I have write a file ssh_to_rtx3080 with the content of ssh rtx3080. I give the path to the file in WinSCP->Advanced->SCP->Shell. But as you can see in the picture, I get an error that server connection is closed.
When I use the terminal on the gateway, there is no problem with that file.
$ cat ssh_to_rtx3080
ssh rtx3080
$ ./ssh_to_rtx3080
mahmood@rtx3080's password:
Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 5.19.0-41-generic x86_64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/pro
Expanded Security Maintenance for Applications is not enabled.
45 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
*** System restart required ***
Last login: Thu Jul  4 09:29:56 2024 from 157.193.244.32
mahmood@rtx3080:~$
I have read the FAQ https://beta.winscp.net/eng/docs/message_unexpected_close but I don't understand what is the problem exactly. Any idea about that?
