Sync Issue: Modified Files Detected but Not Copied
With a WinSCP (6.3.5) script, which I call once daily via a batch program, I want to mirror and keep the local drive
The script:
Log file excerpt:
Does anyone have any advice? Thanks, Martin
K: in sync with a folder /media/Backup/"Backup K"/ on a Raspberry Pi 4B. Unfortunately, this only works "in principle." In detail, I observe at least two files (7z archives) that are not being mirrored again despite their content changing daily. The log file (excerpt below) shows that the modified files were detected ("included to synchronization," "modified comparing to remote file"), but they are still not copied.
The script:
option batch on option confirm off open sftp://user:[email protected] lcd k:\ cd /media/Backup/"Backup K"/ synchronize remote -mirror -criteria=time -rawtransfersettings ExcludeHiddenFiles=1 -delete -filemask="|*/$RECYCLE.BIN/;*/System Volume Information/" /log "C:\temp\winscp.log" close exit
. 2024-10-12 06:11:27.754 Local file 'k:\Music\Trackstat_Backup.7z' [2024-10-11T20:10:45.396Z] [4327105] included to synchronization . 2024-10-12 06:12:11.531 Local file 'k:\Music\Trackstat_Backup.7z' [2024-10-11T20:10:45.396Z] [4327105] is modified comparing to remote file '/media/Backup/Backup K/Music/Trackstat_Backup.7z' [2024-10-08T20:10:49.000Z] [4314786] . 2024-10-12 06:11:27.962 Trackstat_Backup.7z;-;4314786;2024-10-08T20:10:49.000Z;4;"pi" [1000];"pi" [1000];rwxrwxrwx;1 . 2024-10-12 06:11:27.741 Local file 'k:\Music\MusicIP_m3lib.7z' [2024-10-11T20:10:31.837Z] [52837819] included to synchronization . 2024-10-12 06:12:00.149 Local file 'k:\Music\MusicIP_m3lib.7z' [2024-10-11T20:10:31.837Z] [52837819] is modified comparing to remote file '/media/Backup/Backup K/Music/MusicIP_m3lib.7z' [2024-10-08T20:10:34.000Z] [52839272] . 2024-10-12 06:11:27.962 MusicIP_m3lib.7z;-;52839272;2024-10-08T20:10:34.000Z;4;"pi" [1000];"pi" [1000];rwxrwxrwx;1
