Authentication failed
Authentication failed.
Connection failed.
Non-anonymous sessions must use encryption.
Connection failed.
But it doesn't work in this wayWhen setting up your FTP server connection, be sure to use FTP with TLS/SSL explicit encryption. Then enter massive-ftp.ucsd.edu as the server or “host” name (port 21), followed by your MassIVE username and password, and the client should connect you to your user file space.
